Skid Plates...
nwoods
nwoods, I was just curious if you ever got your steering knock/rattle fixed by having put in those new bushings and control arms. Mine still knocks even after steering column being replaced (both upper and lower), under warranty, but not as much as before. Sorry Houm, didn't mean to hijack the thread...
I have replaced the steering column bushings, the upper and lower control arms and bushings on both sides of the front, the swaybar connections and bushings front and rear (both sides each), and one halfshaft (front drivers side). Clunking has gone away, but it took 18 months of persistence with 3 different dealers to have it all done.
nwoods
nwoods, I finally took your recommendation and purchased Rasta front skid plate but having hard time to install it.
There are only two pieces and felt kind of dumb that I still haven''t figured it out
So, small piece should go somewhere so it can hold weight of front part of the skid plate but where??? I don't have to drill holes or do I?
Here are some images that might help, sorry for the crappy quality, was nearly shooting in infared to use available (very little) light.
nwoods
The little flexible rubber dam thingy stays where it is, does not need modification. You will also note that I am using 10mm Grade 8 bolts instead of the relatively flimsy hex headed bolts that come with the plates.
Okay so I need to re-acquire this thread!
Nathan, thanks for the insight...but I have to ask for one point of clarification: Does the Transfer Case Skid replace a factory unit or is the T-case exposed without it?
nwoods
It is my recollection that the transfer case is exposed, though in the many off road situations I have led an LR3 through, I don't recall it ever being a real vulnerability. Gas tanks are another story.....
yeah, I know it's tucked up there pretty good but I thought it was exposed as well. The gas tank has some protection, doesn't it? I'm gathering that the thin metal plate around the gas tank simply isn't adequate....from what you and other posters have said on this forum.
nwoods
I'm on my third gas tank now due to the paper thin flimsyness of the OEM skid plate that holds the gas tank up into position. By far the most expensive work I've had to do to my truck since the day I bought it.
HighCountry 4x4 in Colorado is rumored to have made a gas tank skid for the LR3, as well as Rover Specialties, but I have not seen either one yet.
Wow...I knew it was flimsy but didn't think it would be SO inadequate. Had to have been some pretty sharp rocks!!!
codemonkey
This gallery has the Hi-Country T-case and gas tank skids. They're not on the web site yet - I'm not sure why, but call or email them for details & availability.
http://grendel.smugmug.com/gallery/6013404_bqJNP#376008378_9GiNc
My LR3 will also be at Flatirons Land Rover in Colorado this Saturday, if anyone wants to see them in person.
jimbiram
I've got the transfer case plate, but had not seen the gas plate. That looks pretty sleek and smooth. I will have to give Matt a call. The sliders got a good workout on Poughkeepsie as did the transfer case plate in late August.
MArsel
