Clear Side Markers?
yrbender
I went with smoked off of EBAY - very happy with the look
You slide the old lamp unit forward against it's metal spring clip - then lift out the back end first. Lamp fitting is a bayonet into the lamp lens.
Refit is reverse - easy to do, just take care not to over-compress the metal spring clip.
Looks awesome. Do you have a part # mine is white too
Boaz
Got mine from RoverConnection.com. Pretty cheap. Very easy to install. Came with the amber bulb as well.
yrbender
I like the clear with black but smoke would look awesome. Coopers look good too real agressive. hope shes not always that clean. what rack do you have on there? I was looking at the LR rack but 1200 k is too much
Chief Justice
cdodkin- looks great. I also have a white 08 and just ordered the black lenses. Just curious. Did you replace the clear bulb with an amber bulb or did you just keep the clear? If so what does it look like illuminated?
Boaz
No, not always that clean. :cool:
That's a Brownchurch rack. Rovers North is the exclusive American distributor. I wanted a lower profile, close fitting rack that only covered the area where the rails are. This was the best option. I added a wind deflector later for the noise, and it's perfect. Here's some less clean pics. :smile:
yrbender
Got my smoke lights today. Is there a link to show how to put these on I didnt get instructions or anything.?
Thanks
Boaz
They are spring loaded. Just slide toward the front to compress the spring, then pull out. The bulb just twist locks into it. No tools. 2 minutes total job time, tops.
yrbender
got the one side in fine went to put the other side in and the clip broke!! Called the company explained what happenend and they charged me for the replacement!!! So now I have on smoke and one yellow the smoke really looks much better
cdodkin
I used orange bulbs (came with my FleaBay kit) - so they light up orange :biggrin:
MArsel
