Wheel Centre Lube
ygrowup
Can anyone tell me how to lube the wheel centres? I have been hunting around any can't find anything on this.
e24kgold
According to the manual Mike, the wheel centers are to be lubed. I just had mine done at the 90k service.
ygrowup
My manual says they need to be lubes at every service. Since I like doing the work myself, I would like to know how.
kwlr3
You need to lube the wheel studs and the raised ring on the hub that fits into the rim. I use Permatex anti seize compound. One application last years. If you have ever had a rim seize to the hub, you'll understand the importance of this easy owner maintenance procedure.
ygrowup
Thanks kwlr3
I thought it was more complicated than that. My old Disco needed a litre of oil in each hub. I thought this was similar. That is an easy job.
Disco Mike
Sorry, I stand corrected.
One thing that is right, no mater what the dealer says, get the tranny services with the proper ATF as well as the diffs or you will be looking a huge expenses down the road.
