How do you keep your rims clean?
Michael Conley
New Jersey
I've got the standard silver alloy rims and the break dust is evident within a day or so of driving after cleaning. Can be tough to get off. Tried Zep degreaser with some success and elbow grease. Now gave Sonax a shot, seemed to work a bit better but still needs a couple applications.
What have you all found that works well? Also is it normal to have break dust accumulate so quickly? I figure it is given the weight of the truck.
Thanks
PaulLR3
Boston
f1racer328
AZ
My wheels are usually coated/polished (I have the black gloss 19") and are super easy to wipe brake dust away.
Clean them every time you clean the car and it just keeps getting easier.
I usually go one of the wheel cleaners made by Meguiars, but they always need some sort of elbow grease too. I usually use a microfiber.
DaytonaRS7
pretty much any iron remover will do the trick.
P21s, suggested above.
I like Carpro Iron X
these will clean your wheels with much less scrubbing than normal wheel cleaner. the dust literally drips off.
However a DIY cermaic coating of the wheels will help keep dust form sticking. I used Carpro 3.0 UK. bought on amazon.
and
switch your pads to ceramic.
I to find the amount of brake dust form the OEM pads to be disgusting. just too lazy to swap them out yet.
If you hit them with pressure wand once in awhile you can keep them looking OK without using a lot of chemicals. The dust is not only from the pads but it is a combination of the rotors & pads. The high carbon rotors that are spec'd are soft and wear quite quick. The pads are spec'd for feel/performance. There are some good , less dust pads out there but be careful as many trade cleanliness for bite/feel/power. The more expensive ceramic options are ok. Many early ceramic pads can feel wooden but I think formulations are getting better
PaulLR3
Boston
Exactly what I was thinking. I'd think twice before moving away from OEM pads & rotors. I remember Car & Driver noting during their road test of an LR4 how exceptional the braking was (both stopping distance and pedal feel) for such a heavy vehicle. And I have never had a problem with warped rotors on our LR4s.
  • joey
