code P2096
ugmw177
Charlotte NC
ok, Son called me from 3 hours away. Cheeck engine light on. parts store read code as P0296 "bank 1 post catalytic converter fuel trim too lean".
No driving issues.
Anyone else had this code come up and what solutions were found?
Rover Range
Texas
Check the 02 sensor, make sure it's tight and no corrosion in the connector.
Also, check cat converter for any hairline cracks in the pipes.
ugmw177
Charlotte NC
interestingly, last year i did not find any obvious issues. It has been a year and about 15,000 miles since this time last year and CEL just popped on today. code P2096.
ugmw177
Charlotte NC
anyone have suggestions on their experience with this code? I am leaning towards an exhaust leak but it is so &$(@#^^ hot i dont fancy hanging out under the vehicle right now and it is being driven every day so it is super hot underneath in the evenings
Rover Range
Texas
Try running some BG 44K in a couple tanks of fuel.
Stuff really works.
powershift
Nevada
Measure the O2 output from a OBD2 reader and compare it with the other side. If its lean then you'll know when its fixed because the numbers will change w/out needing to wait for the light to come on.
Sid1577
