N
nemchenk
First problem with my new Landy!
Driving back from its old home, we noticed that the speedo was way out -- it never seemed to register anything above 40, even when it was clear from surrounding traffic we were doing around 70, and jiggled a lot.
I've checked where the cable enters the back of the speedo, and where it comes out of the transfer box, and both seem secure. I've noticed that the outer plastic sleeve of the cable has melted off in one spot (about 5cm long) where it was near the exhaust.
On advice from two other Landy owners, I also took off the gearbox end of the rear propshaft, to make sure the nut behind that was secure (it is.)
Any other ideas? Someone said the tyres or diffs might be non-standard -- the tyres are 205/80R16s, and the difss... how would I know? Is there an easy way to tell?
Anyway, any advice would be appreciated!
Edit: Oh! And how much torque should I apply to the propshaft-to-parking-brake nuts? My Haynes book doesn't seem to list this...
Thanks!
Thanks!
