08 RR HSE LR4 4.4 Fuel Gauge reads 3/4 full when filled
MNFish
Richmond MN
My RR 08 4.4 HSE with 183k miles reads 3/4 full when it’s filled up. That’s probably better than having it read empty when it’s full but would like it to be correct. Can it be calibrated or does it need a new fuel pump sender? And if it needs a new pump/sender what’s that like to change out?
jastutte
My RR reads 3/4 full when it’s filled up. That’s probably better than having it read empty when it’s full but would like it to be correct. Can it be calibrated or does it need a new fuel pump sender? And if it needs a new pump/sender what’s that like to change out?
you're better off in the Range Rover L322 forum for these questions. this is an LR4 forum.
MNFish
Richmond MN
Oh I’m sorry. Is my 2008 Land Rover Ranger Rover HSE 4.4 not an LR4? The title only said HSE 4.4 on it. And it isn’t the sport model. So then it’s a L322?
MNFish
Richmond MN
This is my RR
Rover Range
Texas
Both fuel senders will need to be replaced.
There's an access port on the left side of the tank to get to the left sender. Fuel pump is on the right side.
MNFish
Richmond MN
Thank you for clearing that up! I was wondering why I couldn’t find many posts on the vehicle. Helps if you have the correct model number LOL!!
