18x8.5 or 18x9 Factory Wheels?
werdnash2002
ALAMEDA, CA
I picked up a second set of wheels for some AT tires. I plan to do the 255/60/19 (one size larger than factory) . I got a set of Range Rover 19 inch wheels that are 18x9 instead of the 18x8.5 LR4 size. I know either one will fit the tires fine but is there any pros and cons to having the 9 inch vs 8.5 width?
DaytonaRS7
assuming the wheel offset is the same, the RR 19" will stick out 1/4" further than your LR4 wheels. the wheels will also be 1/4" closer to the suspension.
the tire will also be slightly more "stretched".
Neither one of these things will be noticeable once mounted on the car.
werdnash2002
ALAMEDA, CA
werdnash2002
ALAMEDA, CA
I have tried to find the same wheels on ebay/google to verify the offsets but haven't yet. He said they came off a 2010 Range Rover Sport (supercharged)
werdnash2002
ALAMEDA, CA
Looks like they are 57 offset vs Factory LR4 53 offset. I used an offset calculator and looks like it will move the tire/wheel 0.16 closer to the frame/suspension. Would this be an issue?
DaytonaRS7
they will be fine. you should not notice any difference. maybe a slight visual since the wheels will stick out about 3/8" more than stock.
it should not rub on anything.
