BKNorCal_99HSE
- Joined
- Apr 20, 2009
- Posts
- 3
- Reaction score
- 0
Last year about this time my driver door would not open from the inside but opened fine from the outside. After removing the door panel I found that the cable from the inside latch to the lock mechanism had broken. A little touch from a friend's welder put things back in working order and has been fine since.
Now a similar problem with the rear passenger door only the door will not open from the inside or the outside. This makes it slightly painful to remove the door panel so before I take that on I was wondering if anyone on this board has come across this? Maybe something electrical causing this? The door still locks and un-locks with the key fob but maybe something else non-mechanical causing my dilemna?
Any suggestions would be appreciated!
Regards,
Brian
1999 HSE 105k mi.
Niagara Grey / Black
Regards,
Brian
1999 HSE 105k mi.
