2005 suspension fault
tomcat88
hi i have a 2005 facelift range rover 4.4 v8 on the dash it comes up suspension fault-i got it plugged in and the guy told me it says (compressor brush card temp sensor circuit) -does anyone know whats up with it , the air supsension still works ok and also my air con has stopped working (not blowing cold air) -the joys of owning a land rover -i am a new member many thanks in advance
First welcome to the forum...
Sounds like a sensor is having an issue (could just be a bad connection)
Air Con stopped working, check to make sure it didn't lose any Freon or you didn't blow a fuse.
tomcat88
hi what is freon? + can i open up the compressor to check the connections or is it sealed ?? thanks
No, you don't open the compressor, I presume you are in the USA, if so, go to any auto parts store and get a R134 pressure/fill guage.
If outside the USA, then I presume you use R134 and can do the same there.
Paul p
