285/60/18 Nitto Terra Grapplers, Access and Crawl mode..
zbysiu23
I have also read people considering the Nitto Grapplers as noisy tires my personal experience was quite the opposite..tractionwise they great as well , may be not as agressive as BFG All Terrains ..I think they are more comfortable and better looking...
Has anybody tried to fit Nitto 285 in the spare compartment on the LR3?
allodial
i just asked nwoods about that in another post.. according to him it would only fit if deflated.
zbysiu23
Deflated..well..ready for off roading..
Mine is not the full size spare the steel one.. I am wondering how wide it is ..
if it is narrower will make the tire larger in diameter... hmm
Thanks
GrahamWelland
I've heard of other people catching the harness actually. It happened once (which I guess was enough!) but I always asked the techs to check for any signs of rubbing whenever I had the vehicle serviced and they alwasy came back with a clean bill of health. Not sure if it was due to a particular combination of suspension position/full lock or what but apparantly it abraided or caught on the wiring in the wheel arch and it had to have a minor fix, tape and reroute.
Like I said though, I've heard of others having the same thing happen.
nwoods
Here's what I can add to the discussion:
1. Spare will fit, but you need to partially deflate it to wedge up in there (down to 10PSI or so), then you can reinflate it and still get it out. Gravity must help I guess!
2. I wouldn't put a full size spare there in an off road situation. Should you get a flat in interesting terrain, it will be almost inaccessible in that location. I keep the space saver there and use it as a resilient skid plate :)
3. Generally, no rubbing in access mode. Sometimes in extreme left turns the driver side will rub on certain LR3's.
4. Generally, light rubbing will be experienced in the rear, just forward of the tire, at the 9:00 or 3:00 position. This will occur in normal mode or off road mode when compressing the suspension such as a hard corner (like a sharp turn on a freeway onramp at speed), or fully articulating the suspension over rocks, gully's, etc... The rubbing is minor and has not caused anyone any issues.
5. There are some LR3's that a the sensor wire (for the brakes I think?) attached outboard on the frame behind the drivers side front tire. This can get rubbed right through causing all sorts of interesting problems. It's 5 minutes work to move this wire to the top of the frame, reusing the plastic clip thingie that it mounts with.
6. The Nittos are good tires. Very stout durability off road, great rain performance on road. Fairly low noise. Mine didn't last overly long, but I got a bit over 30,000 miles on them in very harsh use.
7. My personal opinion is that the Cooper Zeon LTZ's are similar to the Nitto, but superior.
Here is a shot of my Nitto's:
zbysiu23
Well...After all the loyality talk to the Nittos..I have ordered the Coopers today...
I hope I did good.. and I hope they will look in place when in driving mode...
Now I just have to figure out best way to move the wires away from the wheel...
I would appreciate suggestins picks etc
Thak you guys, by the way...
Chris
Anyone have a picture of the wires that need to be moved? I don't see them on my '05 HSE.
duckdive
This is my 06. I believe these wires are for the height sensors (upper set of wires).
I almost rubbed mine out a couple of trails ago. I'm lucky to have a skilled friend who
bolted this plate on for me. It will protect the wires no matter what size tires I'm running.
I would hate to break these on a difficult trail and be down on the bump stops for
the rest of the day.
zbysiu23
..THAT IS A GREAT VIEW!!!
I guess .I'll try to use ties of some kind?????
duckdive
Yep, just like Mr. Woods said. I had to do the plate thing because I did not have
much slack in the lines. But if you do, it's easier to just tie them up out of the way.
Good luck.
MArsel
