93 range classic hesitation sag stumble
Tbonejones
I am having problems with my range. she stumbles when i set off. already checked maf tps and idle air. what are the specs for o2 sensors? what am i forgeting?seems like the computer is telling it to go super rich. anyone else have or had this problem?
Can't recall if the 93 has Fuel injectors... could be there are getting old.
Could also be a sign the fuel pump is on its way out... check the fuel pressure. Also when is the last time you changed the fuel filter.
Tbonejones
doesnt seem to be a fuel problem. she seems to idle up after a long start. just when i hit the gas she starts stumbling over her self. also if left alone after she is at op temp she cut out.
Could be injectors going bad, or I would still check the fuel filter.
Paul p
