95' cisco 145k 0il leak
panman
Team, I have a 95' disco1 w/145k miles, drive fine, but I have a nagging oil leak. During my last oil change at the local shop, I was informed that it may be the rear seal. Should I be alarmed, I know that rovers do leak but I am getting worried. thanks
Be alarmed when it stops leaking.... it means your out of oil.....
Other than that if it isn't leaking more than a quart an oil change I wouldn't worry.
97rover
If you really want to know where the leak is on your next oil change put the leak spot dye in and with a small black light look for it. How much oil does it leak? Keep checking your oil daily. Rear main seal had mine replaced for $300.00 stopped leaking.
