95 Disco Alarm dosen't flash lights anymore
S
strider
Hello, my 95 Disco alarm stopped flashing signal lights when it's activated/deactivated. The alarm works normally otherwise. Anyone with info on this problem?
Thank's Joe
Either the battery in the remote is going dead, or you need to lock/unlock the door with the key a few times to get things happy again.
S
strider
Hi, thanks for the reply. The battery in the remote is new so that's not it, besides it works the doors and the alarm. The problem is that the indicator lights ( turn signals etc.) no longer flash three times when setting and one time when canceling the alarm. They used to do that fine. I tried with the key but get the same results. I'm wondering if somehow I've accidently canceled this feature of the alarm?
Joe
The only way I know to cancel the feature is via Testbook (LR computer) or similar ECU probing computer. Otherwise it sounds like one of the door acuators or the hood sensor is not working correctly. If the lights do not flash, then the alarm may not be setting itself.
