95 disco questions
jesusfreak2111
Hello everyone and thanks for the reply on my window problem. I also noticed today that my cruise control does not work. Maybe I am doing it wrong I don't know. Do I just press the accelerate button on the steering wheel or is there something else I should do? if I am doing it right, what should I check to see why its not working first? and what size bulb does the rear brake light and 3rd brake light take? Thanks n advance.
You also have to make sure the cruise is turned on... the button on the center console that looks like two lines with a bridge across (stands for highway if I recall correctly).
if this is on and the light works, then you have to pull up on the accel button.
Sid1577
