95 Disco with a bad cylinder head gasket
chastings
So I yanked the heads off. There was a metal gasket that matched the block. LOTS of sealant, which I thought was a little weird. The block looked fine after I cleaned off all the sealant.
The Machine shop had the heads for three weeks. When I got them back they said they had to shave them .006, so hopefully it was just a gasket.
The problem is that I bought a gasket set from Autozone (Beck Arnley, PN 032-2992). They guaranteed it would fit my engine. It doesnt. It fits the heads, tho. The problem is the 4 bolt holes on the outboard side; the engine has them, the heads dont. The old gasket fits the engine, but not the heads.
The heads are casting numbers HRC 2479 10 and HRC 2479 11
No idea what the engine is.
Thanks all!
C
chastings
Continued
I should have mentioned my question!
Is this OK? Can I use this gasket?
Thanks!
C
alzerom
The obvious question would be are you sure those heads belong on that block?
chastings
correct heads
I think so; I called PT Schram and he said they were. Im going to install everything today (I got the bolts yesterday)
Wish me luck everyone!
STQAddie91
