'95 Discovery keeps showing Code 45 after resetting codes! What to do Next???
A
AtlasEngr
The Discovery stumbles a bit once in a while. Sometimes I can use it and it works magnificent. I looked at the OBD1 LED readout under the passenger seat and saw that code 45 is showing. I disconnect the harness, connected it after 5 seconds, turn ignition off and waited for the relay to let off. Then when I turned the ignition "ON", I got the same darn code 45 every time!
The previous owner replaced the passenger side O2 sensor (as well as the IAT, Coil, Wires, 'plugs Dist.cap, rotor, & fuel regulator) and I look at the connections and they all look good. I checked voltage from the main harness to the O2 sensor and this is what I got.
Voltage at white wire for passenger side: 11.85-11.90 V
Voltage at blue wire for passenger side: ~11.50V
I also checked for voltage at the driver side white/orange wire: 11.96-12.0V
Both black wires on the O2 sensor main harness were giving good ground.
Is there anything else I can check myself to try and tackle down code 45?
I did try to reset the code at least 10 times and I got code 45 as soon as I turned the ignition "ON".
Please let me know what I can do prior to dumping money at the dealership.
Thanks,
Paul
Sounds like a connector issue. I would disconnect the O2 sensor in question and clean the connector with some contact cleaner add some de-electric grease and reconnect.
95d1
To clear the codes I take out the fuel injector fuse under the hood in the fuse box for 5 seconds or so. Check that the o2 sensor is clean too. Drive it in firts gear with the revs high or take it out and burn the crud off with a propane torch. If this dosn't work switch them and see if the code changes to the other side.
A
AtlasEngr
Disconnected battery and all to reset the codes. Codes went away and then code 02 came on. This went away after the second time I put the ignition on "ON".
I swapped the O2 sensors from their original location and drove around for a while and no code. Well after driving it at a later date for a while ~20 mile trip, code 45 is now back on!
I have the RAVE CD for the Discovery and what I need to do is pinpoint an electrical problem with the passenger side O2 sensor connector.
Does anyone know where to start first or a good plan of attack?
Thanks!
A
AtlasEngr
Someone make sense of this diagram!
If anyone can break it down. Please let me know.
Thanks!
Tumbler
