99 disco help
avengermike
hey guys new here, i did a search to see if i could find the answer to my question but no luck.. I have had my disco for about 3 months now and have tested the tracrtion on this bad boy, but not impressed with it. Im sure their is something wrong with mine because all i get is wheel spin. i dont have any lights on saying anything is not checking in right with the computer. last time it snowed i took it out and if i hit the brakes the front would lock up fast with normal pressure. tried to go up a hill that had some wheel flex but other then that dry dirt. tires with no tracktion spun. i have did the abs mod - http://www.landroverclubvi.com/abs-mod.html - thinking that might have something to do with it, but no change... ps also if i try to turn thte downhill decent on i hear three chimes and thats it no lights and no change with the disco...
Read my reply on the other site and get back to me.
First you sound like you have a D2, not sure what ABS mod you did, but if you disabled the ABS, then you will get wheel spin since the ABS is your traction control. I would recommend adding the CDL lock to yours not read hard nor very expensive if you do it as an add on and not a full kit.
But wheels locking up in the snow sounds like ABS issues.
Rangerover2016
