A/C leaking Water in my Disco
62Sunbeam
I know it's typical for a car's A/C to drip a little water under the car but mine seams to prefer to leak the water down the inside right of my trans tunnel leaving the carpet and my wife's purse wet.
Is there a tube that needs some compressed air run through it or do I need to disassemble the cars starting with the rear bumper and working my way forward until I find the $1200 part that's out of production but is available used on ebay?
Please offer suggestions at the risk of great appreciation.
Thanks
Eric
95 Disco 181K miles
D
disco1
If you do a search on the forum you will find heaps of repair suggestions.
Good Luck.
BTW, I got a chuckle from your post.
Slam
Supporting Member
Supporting Member
You have to clean out the a/c line with an air compressor. Just blow crap out of it and you will be set.
The are two A/C drip lines, if you crawl under the disco at the drivers or passenger front door, then slide inward, you should see if you look hard one tube on each side of the Transmission, each will or should have a little ****** on them. When the clog up, water backs up onto the floor inside. A wire coat hanger works, but remember it is full of nasty water and who knows what else, so keep you mouth closed and where some goggles.
Sturgeon
