A/C Problem on a 2004 Disco
Disco Ru
Hi, this is my first thread so here goes. I have a 2004 Disco SE and recently the A/C will only blow out of the defroster and floor broad vents even when I change the setting on the Climate Control interface. I have checked the fuses and such but cannot find any reason way it is doing this. Cold air does come out of the dash vents but not with any force. Has anybody else encountered this problem?
Disco Mike
You are going to need to get it to a shop where they can test to determine if it is a vacuum gate that is not opening as it should or the control unit, itself, that may be failing.
STQAddie91
