ABS light anti lock light question
N
nick325ic
When I start my disco the Anti Lock light is on, but when I put it in drive and move about 10 ft. or less it goes off, it never stays on so I haven't worried about it but know am wondering why it might be doing this??? Please help shed some light
D
disco1
If all is well the ABS light should go out after you move off. Sometimes you may travel a few hundred metres before it goes out. If it doesn't go out, turn off your ignition; wait a moment, then switch your engine on and drive off. If it still does not go out then it could be a sensor problem or someting more serious.
ColeCam
the abs is doing a self test and kicks off at approx. 10 mph. if you drive under 10 mph it will stay on indefinitely, but I have never managed to do so very long :) In other words it is completely normal, as Disco1 said.
N
nick325ic
thanks for the info. guys I feel much better about it
STQAddie91
