ABS Light doesn't turn off
msozturk
Hi,
I have a little problem, when I start the car, the abs light doesn't turn off. After I start driving it turns off automatically.
The dashboard screen does not give me any error message related to ABS.
So what might be the problem?
I tried searching the forum for: abs error however the keyword abs is automatically neglected.
Can somebody tell me how can I search for something related to ABS or EAS from this system?
Regards
lsawicki
I believe this is normal because the car needs to be moving to test the ABS, then turns off if it is working.
97rover
This is very normal. The light is on because your vehical is performing a self test on the ABS system. It doesn't normally turn off untill the vehical speed has reached 5 MPH. if the light stays on after the car has moved faster than 5 MPH and does not extinguish then there is a problem with your ABS and should be looked at by you or a mechanic.
Sid1577
