AC stopped working
Gliardon
AC just stopped today. Blower works but it doesn't sound like compressor is kicking in...thoughts.
bbyer
Alberta
Got the Rear Heater AC setup?
Do you have the rear heater / AC setup? If you have, did it quit as well?
A problem in the front system does not necessarily mean the rear system will not work. Also does the heater work? I see that the front fan works so maybe it is just the R134a has leaked out and needs a recharge.
When I did the recharge, I used the R134a with UV dye to make finding leaks easier the next time.
http://www.autozone.com/autozone/ac..._/N-261q?counter=0&itemIdentifier=425681_0_0_
socalrovershop
could be many things . easiest thing would be to check the pressure. Even easier hook up a good scanner and see what fault code is stored in the hvac module
You are most likely low on 134 which is an easy thing to correct by buying a large can of freon, including the hose and gauge, follow the direction and you should be fine.
PE_in_UAE
