Blower motor fan switch plug
Big Chef
Apparently burning out this plug is a common condition. The two discoverys I've found in salvage yards both had this plug burnt out. The burn in on the far right the white and black wire...I'm guessing high speed on the fan switch. Anyone know where I might find on of these online? Winter is really going to be a drag without a defroster!
Thanks
The best way to fix this is to just make your own plug or wire them together. the switch itself is not rated high enough for the job.
Big Chef
Just what I ended up doing...thanks
Now, anyone else have the high beams go out when they hit the switch?
High Beams going out with switch... sounds like the switch may have gone bad... if you take it off (not really that hard) you can open it up and clean the contacts, add some de-electric grease and be back up and running in a little over an hour.
Paul p
