Blue devil sealer
ysaga
Any advise regarding using Blue Devil sealant for the cooling system to seal a leak on the heater and manifold ?
Disco Mike
I like nearly all the products made by White Shepherd, but stay as far away from Blue Devil as you can. I have talked to more people who have used it, that in turn plugged up there radiator and t/stat.
Why are you needing to add stop leak to your coolant system?
ysaga
The heater is leaking inside the car and when I bypass the line in the engine compartment(temporary repair ) I start to have a leak on the lower right side next to the oil pan in the front ?!?
Disco Mike
Even a good stop leak won't fix these problems, time for a couple repairs, how mechanical are you?
ysaga
Ok Mike give me the bad news :help:I like my rover do not tell me I need a new engine ?!
ysaga
Mike I need your advise what you suggest ,the water pump gasket was replaced and the leak is close to oil pan ??:albertein
PE_in_UAE
