L
lacarruk1
Jayhawk said:lacarruk1 said:There is a MUTE on the back of the radio. Just test the Parrot mute wire on each connection until you see PHONE MODE appear on the radio screen. It worked for me when I was using the CK3100. I also used an amplified speaker with mine and it sounded great. If anyone is interested, I just listed it on eBay as I just picked up a 2006 LR3 HSE with factory PTI Bluetooth.
Lacarruk1 -
I too have a Treo 650, and am curious about the Bluetooth functionality on the LR3. The salesperson told me that without a dockable phone, the only abilities I would have is to answer the phone. He said that nothing would be displayed on the screen when I receive a call other than "Incoming call."
Is this true, or will it display at least the incoming number?
What about outgoing calls? Can I voice dial by number? Is the numberpad on the phone enabled for dialing numbers?
I'm having a tough time finding any answers on this.
Thanks,
Jayhawk
As I learned, they don't know what they are talking about. Over Bluetooth, you will be able to see incoming phone numbers on the radio and dash computer, you will be able to use the keypad on the radio for dialing numbers, you will be able to use voice commands, you will even be able to use your NAV system to type phone numbers in and then enter voice commands to attach to them.
The dock gives you the ability to see your entire address book through the radio screen. This is the big plus. Other than that......No big deal. I am not sure if you would see CALLER ID NAMES with the dock though. You do not see names over BT, just phone numbers.
