Bought a Factory brush guard for my D1
P
paulbrapp
I just purchased a wrap around brush guard for my D1. I am unsure how to properly install. Any help would be appreciated.
Thanks
Moose
Get big bolts, and some nuts to match them. You use existing holes in the frame horns. Have another person there to help you line it up.
R
ricklandrover
Make sure if you have to cut the lower part of your plastic bumper in order for the lower mounts to go through you cut the at least 1/4 inch larger than the brushguard mount. When you are at high speeds brushgeards tend to vibrtae and if the bumper mounts are touching the lower bumper it will cause the bumper to crack and once it starts they are very hard to stop..... and yes I know from experience, I had to buy an entire bumper since it cracked so much, I could not glue it to salvage it!
P
paulbrapp
I will put some on hopefully today or tomorrow. I only had to cut the bumper a little. Thanks for your concern!
tragic1
