Broken hub/lug bolt
gregzilla
Ok did a brake job on my disco II and while torquing down one of my wheel lug nuts the bolt/stud snapped off. It's a pressed in stud so I called the local dealer to get a new one. They said this part is anot available separatey and that I had to buy the whole hub. They also siad there is no way to get it past the bearing retainer if I wanted to put a new one in...
Is this all BS? Seems they should be able to be replaced (Ihave not tried pushing it all the way back thruogh yet).
I guess worst case scenario I get something with the same thred and weld it into the hub.
Ideas?
First, how in the world did you snap the lug off?
Second, I am not sure if you can order/replace them seperatly or not. Either way I would contact Will Tillery @ Roverguy.com and I am sure he can get you a good deal on either the lug if removable or the whole hub.
gregzilla
he he...just me and my arms...probably was already streched at some point
you were right he had the answer and the part
thanks!
Will has always taken good care of me and anyone I send to him... I am glad he and I could help.
No I Do not receive any kind of kick back or anything from Will... just a fellow Rover guy.
BCNJ
