Can Disco II Doors be adjusted for Fitment?
J
jm_prindle
Hi
When replacing the door lock actuator on the drivers side rear door, is the entire door removed? If so, can the door be adjusted for better fitment? The door giving us trouble had its lock actuator replaced recently.
Basically, we noticed a lot of wind noise coming from the drivers side rear door. I thought the main seal was probably worn (75K on the truck) until I looked closer at the door. When the door shuts, the entire top of the window frame wiggles noticably. Also, the gaps between the body, and each the front and rear doors (when shut) are different than the gaps on the passenger side of the truck. I'm not talking about a gap difference via tape measure either, One one side I can stick my finger between the door and the body when shut, and on the other I can't.
The truck has not been in any accidents, I purchased it new in 2001. Any ideas? How much gap is acceptable? Can I adjust the door or should I just replace the seals?
Thanks
John
Sounds like someone broke into it at one time and bent the door frame.... I would go by a good body shop and have them look at tweeking the door back.
J
jm_prindle
I doubt that anybody tried to break in - there isn't any damage as though there had been an attempt (such as scrapes or missing paint) and I know nobody has ever succesfully broken in since I have never found it open or had anything missing. Any good theif would just break the glass..
Thanks for the reply though - I will swing by a body shop to see what they think.
BCNJ
