Can I Disable Tire Pressure Warning Light Somehow?
Sonies
Is there any way to just disable the tire pressure warning light? I know when my tires are filled up or not... I don't need this dumb warning light on and was wondering if there is a way to disable it perhaps via removing a fuse or something? I looked around many internets and found nothing.
TIA!
Trynian
Yes but it has to be done by a LR shop computer or faultmate. Have to change the car config file to no TPMS fitted.
Sonies
can i also then have them turn off the stupid and buggy gas door open sensor as well?
might be a worthwhile trip to the shop to get all that done
IIDTool can turn off TPMS as well (spare tire monitoring only or the whole system), FYI.
Trynian
Is it gas door or gas cap warning? I don't have a gas door sensor on my 06 SE so I would have to look at the car config files again to see if it is an option. But it probably functions similar to the hood sensor and can be bypassed if needed.
Sonies
I don't remember which one, all i know is that it goes on for a few days and then off for a long time. I want to say its the door, but could easily be the cap. Hasn't happened in a while so I don't remember
how much is an IIDTool? I can't find pricing and well, to be honest not sure I want to be jacking around with my electronics too much. I was hoping it would be like the hood sensor fix with the paperclip and foil :)
Anyone from Chicago know a shop that isn't a stealership that could possibly help me with my issue?
stmcknig
There isn’t a sensor/switch for the gas cap or the door. It's part of the "maybe this is why the EVAP system triggered a fault" - often it's a loose or poor sealing cap but can be something more involved. Fault codes should help. So sadly, I doubt paper clips will do much here ;-)
Sonies
funny enough my yellow engine light is off now after about 6 months of it being on for no reason, but the TPMS is still showing the yellow (!) above the gas gauge.... lol
who the heck needs these dumb poorly reliant sensors anyway! keep it simple stupid!
Trynian
I didn't think so bu wasn't sure if it was something on newer models or not. But the check engine light means it is the gas cap open or leaking fault. But usually in my experience and with several friends it was the DMTL pump that caused the fault.
stmcknig
The check engine light can come on for any number of reasons once a computer threshold is reached - one of the most common but not the only reason is the loose/faulty gas cap. That's why you need the fault codes....
PanKyiv
