Clunking Sounds
LDRSHIP
I have a 2005' LR3 that seems to be making a strange Clunking Sounds. The sounds seem like its coming from the rear and it happens every time when I come to a stop, then get back on the gas again.
Can some please help me determine what this sound might be!!! :help:
Mx468
Its probaly your wishbones/control arms or your front/rear arb - anti-roll bar bushings.
Type in arb bushes for LR3 and you'll find tons of info on them.
CGoodwin
LDRSHIP I have had a similiar problem lately. Any luck finding the problem?
devildog01
Front or rear a-frame bushings. Just buy poly-bushings. Other people or the dealership may try to sell you new a-frames but the lr factory bushings a garbage and you will be doing it again in no time. Try Lucky8llc.
srschick
unless you have a good workbench with sufficient tools and the ability to press in bushings, replacing the entire lower control arm is the best route.
srschick
FYI, lucky8 does sell the LCA with poly bushings already installed.
