Cold Water Leaking by Foot Rest Driver Side
militarynvy
I am sure there has been questions on this subject but I wanted to post another since it's my first time here lol...
I am getting Cold water leaking into the Driver side foot rest while I am driving and ac is on. It is not Colant already checked nor is it washer fluid. When driving and make a turn to the right it's seems like someone pours half a cup out of the black lid just right above the foot rest. I can stick my hand up in there and it almost feels as if my car is collecting humidity while the ac is on and then dripping out. What can I check for before taking my 1999 Range Rover 4.6 into the shop. No there is no water on passenger side. Just a little bit coming in on Driver's side.
When I stop and look underneath my car i get some leakage right underneath the body carriage and it's in the same spot as were my foot rest is located. Any ideas and or help on what to look for?
A/C drains are clogged... it has 2 one for driver and one for passenger... right next to the transmission, crawl under and clean them out.
I used to use a coat hanger to clean out the drain tubes on my disco2's. It worked great for me. Just be careful because if it's clogged a whole bunch of yuk yuk is going to fall on your arm and or face. Clean both of them since your under there, good luck!
