Hi to everyone. Hope somebody has had this problem. When I turn on ignition (position 2) both the fans are running in slow speed. This is regardless of AC switch position, when starting from cold in the UK with outside temp of 17 degrees c. Just seem to run all the time. They stop when ignition off. I have pulled fuse 31 for now to stop them running all the time. I have swapped out the relays etc to check so the call to run is coming before the fuse box! any ideas anyone.
