Coolant
discomk
04 DISCO HSE7, 52K plus. would like to flush out the coolant with new ones. where is the drain plug? :smile:
Bottom radiator hose... but you might want to change all the hoses while your doing this work... it will save issues later
discomk
do i need to take some 'covers' off to see those hoses? can't see them just buy looking up (from under). forgive the ignorance, pls.
front of vehicle look on the left side (passenger US spec Disco) down at the bottom of the radiator you will see a 4 way hose.
beemer
This is exactly why when I had a custom extra thick radiator built by my family lifetime friend if 65 years added a petcock on the long brass pipe befor the hose. Between this and the block drans a complete system drain.
Hey Joey if your around, where can I get a brass radiator fill, burp plug as the plastic one
split 200 miles from home in the mountains? I got some epoxy and glued the thread stub in 4-5 threads to get me out and home. Dealers only have the same plast crap I want brass.
I either got mine from atlantic british, or dap-inc, it has been a while, so I am not sure.
beemer
Thanks guys for the fast replies, i'm on it big time.
As I added to the above OP thread the added petcock
fitting in that long 80 degree olwer radiator brass tube stub cries
with space to add a petcock. You'll be so happy later should any
coolant draingings or changes need to be done.
Remember those block plugs also plud flush the heater core.
I would run distilled water only as a flush say a 5 mile after at
normal temp with heater on. Then drain and add your anti-freeze
with distilled water mix only not tap water. Tap water will have
acid base chemicals bad against the alumimum motor.
JMO's passed on from a 60 year in the business radiator person.
He built a special fully brass oversize in thickness radiator
for me plus added that drain petcock.
discomk
i was told its best to drain the coolant while the engine hasn't been started overnight, is that true?
also, can i flush it with my gardening hose or should i use distilled water.
discomk
oops, beemer nut just answered my 2nd question. thank you.
PE_in_UAE
