Coolbox Install
mmbirtcher
I picked up a Coolbox from a yard that was tested prior to me getting it. When i connected it to the LR4, it briefly came on then stopped. The switch was also briefly illuminated. Checked the fuse, which appears good - although I’ll switch it out anyway. The plug from the car has no power. I believe that should be energized when the car is on? Maybe I’m missing something? What should I check?
Thanks
Cthehentz
Las Vegas
Is there an amperage rating on the cooling box or what does the fuse block diagram call for?My R3 has a cool box but not the my R4 so I would assume they have different ratings.
mmbirtcher
The fuse is a 10amp. I have to figure out how to power the Coolbox to test it.
mmbirtcher
That won’t be too many amps? That’s the only reason I didn’t try that yet!
PE_in_UAE
