Couple issues
xconcepts
I noticed today that my exterior temp is stuck at 80 and I know for a fact it is not 80 in Turkey. It was showing 109 a few days ago. I don't seem to have any other issues with the command settings. Anyone know possibly why? There are no LR dealers here.:frown:
Also, I tried the Terrain response setting today and noticed when I was at a dead stop and accelerated to a left or right turn I felt a vibration from the front end and hear a slight noise, not there if I was already moving and went to turn though. I can duplicate it but it doesn't do it in normal mode. Is this normal? No warnings or anything are showing.
Edit: I notice that it is on all settings but normal, could it be cause it hasn't been used often?
tommithy
It is most likely a bad sensor. You will need to get it replaced.
When you were in a different Terrain Response mode did you also happen to be in offroad height? If in offroad height and turning from a stop and feeling a vibration could be indications of a bad CV joint. Something an experienced LR mechanic should look at as well.
xconcepts
No, I wasn't in offroad height. I thought the same thing at first. If it was a bad CV joint wouldn't it do that at every setting, including normal?
tommithy
If it's just starting to go it may only show symptoms in offroad height.
I'm outta ideas.
xconcepts
Thats the thing though, I'm not in offroad height. I'm sitting at normal height. Guess I'll try this turkish dealer and see what they can tell me. Wish me luck
