Cracked Gasket or seal around windows
M
markdrm1
Hi,
I have a 99 Disco with the old style gaskets or seals around the rear side windows and cargo door window. Unfortunatly the previous owner let these gaskets dryout to the point of cracking in the top corners. Does anyone know where (other than dealership) you can buy these? Also, is this an easy fix or something for a window repair person?
Thanks!!!!!
Not sure where to buy them, but you can use some black RTV adhesive/sealant. Just tape it off, apply sealant and wet finger with water and smooth out. Did mine about 3 years ago and I may need to fix it again soon, but for all of $4 for the sealant I will not complain.
You can only see the sealant from up close
tragic1
