dash repair kit
P
pete2528ca
i just noticed on my 97 disco that the dash is starting to lift on one small area about two inches long. Is there some way of repairing that area to avoid buying one of those repair kits? The lift is on the passenger side where it starts to curve up and over if that makes sence...
pete
Monkey glue works wonders.
P
pete2528ca
so just put a little monkey glue down and put some weight on the part, and that should do it?
That would be my plan.... as far as a recall on the dash, not that I am aware of. Most things for recall are safety related.
Most things for a LR are called TSB or technical service bulletins. These are not recalls, they are just heads up for the mechanics, if under warrenty they noramally are covered... after warrenty... $$$$$
