dripping water from under dash
loboz111
Hi all,
I am trying to locate the drain hoses for the condensation of the a/c...My carpet is all wet & I was hoping for an easy way to clear them. any help is very appreciated.
thx
Lobo
loboz111
Well forum gurus,
after reading back some of the posts, i saw where to use a coat hanger or wire to clear the tubing....i tried this & about to go for a beat run....hope it workz.......thx for the info & edu.
Sorry no one replied... I know I for one was enjoying a day with my kids at the Renaissance fair.. Also depending on the year of your Range Rover, if the A/C drains do not fix it... you may have a bad heater Core. Smell the water if Anti-Freeze smelling.. you may have issues.
loboz111
Hi joey,
thanx 4 the info....the water was clean & no anti-freeze odor....i cleared the lines & found the end under dash almost off....problem solved.
Thx again
lobo
rlewis15@hotmail
I have a 08 range rover hse, and am having a very strong musty smell every once and a while? There is no wet spot on passenger floor. I've had the pollin filter changed and the cabin air filter was check and said to be new? Do anybody no exactly where the water should drain out from under neath? Was thinking maybe it was plugged but can't find the hole? The smell can be so terrible it burns my eyes:(
loboz111
I know on my 98 i found 2 ******* above the tranny underneath. If you squeeze them, they will open & allow you to run a piece of coat hanger or brazing rod up them. Cleaned mine up well.
Gl
lobo
STQAddie91
