I am a new owner of a 2000 Land Rover Discovery II with 100,000 miles on it. So far, I've been fixing mostly costmetic issues and it runs great. The main issue I have is the drivers door will not unlock. Neither with the FOB nor the key itself. The only way to open the door is to climb over from the passenger side and using the door handle to open it. Oddly enough, when I go to lock the driver door, the latch will not manually push down until I close the door once, re-open it, and then manually push the latch down. When I try to use the key, it seems like it is not going all the way in.
Also, I cannot use the FOB to lock the drivers door and cannot use the key to do so either. All the other door locks work great!
Any help would be greatly appreciated!
-Andy
-Andy
