External mirror replacement
V
VTVV
How much work is it to replace the outside mirrors on a D1? My brother's have taken a beating in the city and need to go.
I'll admit I haven't done much looking (he's only up for a day or two at a time), so forgive me if it's painfully obvious once you open up the door panel; I just figure that with them being power, heated mirrors, there might be a catch.
The dealer apparently asked $600 for the pair, so I'm thinking that if I can snag a couple off a wreck of something, that's the way to go....
LRWheelman
Hey, Mark- I got one at A/B for only a couple hundred bucks & they are real easy to install, took about 30 minutes if I remember right. You don't have to remove the door panel though, just the triangle piece of plastic on the inside. Good Luck , LRW.
PE_in_UAE
