Freelander TD4 Automatic Gearbox
lean
Hi all
I've an Automatic Gearboxed FL Td4 year 2001. I'm going crazy with my Automatic Gearbox and none of the official mechanis in my zone had solved.
I try to explain... I change the gear (manually or automatically) and a big BOOOM blows up from the rear. It seem like a manually gearbox when you release very "hard" the clutch.
first.... BOOOM.... second.... BOOOOOOOOOOOM..........third
the changes from second to third is really really like a "rip off"
I've noticed that when it works fine, the delay of the gear change was about 1 second... the next (or the previous) gear change was very soft. Now that I have this problem, it seems that the gear is inserted immediately!!
I hope I had explain and I really hope that someone has something to advice.
ps.
I've changed the oil... Texaco Automatic Transmission fluid
I've done an electronic test with no errors..
