Front end noise
I have a 99 Discovery 1 SD with 135k and Im getting pinging noise from the from end. Would this be the bearing. I know that passenger front side needs replacement. Would this assumption be correct. Im guessing this is something I couldnt do myself. Any help would be appreciated.
Pinging noise, is it in rhythm with the engine rpm or vehicle speed?
Is it only when you turn? Brake? In 4x4? Is it worse under load?
What grade of fuel are you using? Last tune up? Fuel pressure at rail?
Is the check engine light on?
Please let us know……..Chongo
