62Sunbeam
Ok so I think I've narrowed my rough starting when hot problem to a faulty fuel temp sensor as I've replaced the coolant sensor and the O2 sensors. I even described the problem to the parts guy at the dealer and he thought the sensor is probably bad.
My question is this: The sensor is a resistance type sensor so can I remove it and check it's resistance over a range of different temps? What should the range of impedence be over what temps?
I'd really like to see if I can double check before I shell out $75-225 for a new sensor.
Any and all suggestions appreciated
Eric
95 Disco
Eric
95 Disco
