Getting ready for the season!
Codename Duchess
I can't tell you how excited I am to go offroading again. (Anyone in Southern/Central Ontario should come out May 7th for a run :) )
One gremlin I'd like to track down is play in my steering wheel. I don't think it's an issue with the actual suspension or tie rods, but it's more u joint/clockspring related. I get about 5mm of movement that's loose at the wheel before it connects to actual steering input. No vibrations at high speed or anything, I can wiggle it side to side 5mm with no effect on steering.
Also, I have an SRS light on for ever, which may be related. Haven't had time to read that code yet.
Any thoughts?
I'll probably replace the u joint anyway, why not.
There is a U Joint at the bottom of the steering column that gets dried out...makes the steering feel "chunky" as you turn the wheel. Like there is a pocket of play in part of the rotational range.
Codename Duchess
That's what I think too, my Dodge did the same.
The play was less than a mm when I swapped it but what a difference.
Good luck; let us know how it goes. Some have lubed; I replaced.
