HDC Fault and Battery
95badger
Hi. New to the board. I have an '06 LR3 with 55k miles. Battery was replaced under warranty at 38k. For the past week, I have been getting random HDC warnings, suspension lowered, no cruise control, amber brake warning and the tip over symbol. I have read that it is most likely the battery. Could it really only last 14months? Or it is sometimes bad connections. Can someone help me understand where are the connections that I am supposed to look at. The ones connecting the battery, or the fuse box next to it, or under the HDC button? Also, if the battery tests fine, I have seen on some boards that the battery could still be causing these warnings. Is there another way to test without replacing it? Thanks for all the help, I appreciate it.
GMT
Had same faults and thought maybe battery as well. Took it to dealership (under fac warranty) and turned out to be faulty brake lamp switch.
GMT points to a common problem which indeed shows those same symptoms. Another culprit (same symptoms) is a bad wheel angle sensor.
davidsussex
