Help code 48 and ac compressor
xxljacket
95 Disco I
I am new to this Disco Mania *** I love the amount of information and knowledge out there.
I have a code 48 Idle air control valve.
Since I discovered the code after some research my service engine light has come on.
Does this mean I need to replace or clean?
any ideas for the Air control valve
My AC also works sometimes and blows cold but many times does not work at all.
I have no idea why the compressor keeps cutting off and does not come on all the time.
I am not a mechanic and adding Freon is about all I know when it comes to AC.
A great idea for a fix or a good repair shop in the ATL area would be greatly appreciated.
Clean the IAC front of the intake you have 2 small parts with a plug going to each... one is the IAC the other is the TPS (throttle position sensor)
Clean them both... be careful with the screws, the strip easy.
A/C could be a bad switch or low on R134a
xxljacket
Thanks,
I cleaned the IAC and the error cleared so that part is fine now.
the system is charged with 134a
What switch specificially are you refferring to?
I have the RAVE manual and will look it up the switch.
Sid1577
