How do you....?
Newrover2007
How do you drive off mode all the time? And why is it if you hold down the lowering lever it beeps? :confused:
Thanks
gtc
Not sure I understand the question - the beep generally informs you that there is something on the display menu. Ie, if you are in access mode and continue to hold the lever, you'll here a beep which indicates that access mode is "locked" (ie, you can drive at greater speeds). If you are looking at driving in raised (off-mode?) height all the time, you're limited to a specific maximum speed. There is a quick modification that you can buy/fabricate that allows you to move the sensors around so that the vehicle stays in raised mode (it believes its at normal height when raised) - and thus allows you to raise to a further extended height via the switch or to "lower" to the old standard height (which it now believes to be access mode).
Newrover2007
That is exactly what I was looking for. Where would you go to get such modifications?
Newrover...what is your intended purpose? Are you going to fit the LR3 with larger tires for offroading? I am not sure I would get the height sensor mod just for the hell of it....
