How to change tires
ntran0187
I am have problems changing the tire for my 1999 Range Rover. The lug nuts are off but the tire is stuck. HELP!
After removing the lug nuts... kick the tire real hard. If that doesn't work, kick it again.
ntran0187
I am afraid to kick it too hard. Because, I had jacked the Range Rover on its axles and the first time the jacked leaned and it got back on its tires. Is jacking the RangeRover on its axles the right way to do it?
Thanks!
That is the way I do it, but I would also put floor stands under there to make sure it doesn't land on me.
Sid1577
