I dropped the oil pan and found...
JJMyerz
Adventurer
Nothing but chunks of oil pan gasket!
But the hard line with the screen that goes into the pan was about 80% clogged with chunks of the gasket.
Can I simply unbolt those two bolts to take it off and give it a proper cleaning?
Thanks
Justin
JJMyerz
Adventurer
oh yea,
since the screen was so clogged I'm thinking this may be a source of my ticking sound.
D
discomike
Justin,
Yes, you should be able to remove the pick up tube and clean the screen. If the debris collected in it is old, yes it could have been part of the lifter noise you were hearing.
Let me know how it goes.
Sorry I missed your phone call yesterday.
Mike J.
JJMyerz
Adventurer
No problem mike,
I figured it out shortly after. The stock sway bar and steering stabalizer need to be removed to get that pan off.
So there is no gasket then on that pickup line? Good. What about torque settings for the pick up line?
Thanks
Justin
Sid1577
